Aercool Aero-1000 Review and Interview
Written by Antony Leather
May 26, 2015 | 08:48
Tags: #atx #best-cheap-pc-case #best-full-tower-chassis #full-tower
Companies: #aercool #nzxt
Cooling Performance
For cases capable of housing ATX or larger motherboards, we use our standard ATX case test kit. which includes:
We disable the motherboard's onboard CPU fan control and all CPU power management features, while the graphics card fan is locked at 25 percent speed using MSI Afterburner. The system is loaded using Prime95 25.11 and Unigine's Heaven 4.0 benchmark. We use CoreTemp and GPU-Z to monitor the temperatures, taking the maximum values after 15 minutes - enough time for the readings to plateau.
Case performance - CPU Delta T
Difference over ambient
  • No case - open test bench
  • NZXT Noctis 450
  • Aercool Aero-1000
    • 48
    • 49
    • 50
20
30
40
50
°C, lower is better
  • CPU delta T
Case performance - GPU Delta T
  • Aercool Aero-1000
  • NZXT Noctis 450
    • 41
    • 45
    • 45
20
30
40
50
°C, lower is better
  • GPU delta T
